If you look the part up in Partzilla, then click on the part number as if you are going to buy it, it will take you to a new page where it describes the part better, and on that page there is a tab labelled "Fitment" (from memory it's fitment, or application..haha  I'm not looking it up for you to check), click fitment and it lists all the other models that part fits.
    • By cruteg8
    • By Mister907
    • By en4cer
      Problem number 1,
      Problem number 2.
      Any help would be nice.
    • By davefrombc
      1996-2003 Polaris Sportsman 400, 500, and Xplorer 500 service manual
      View File Polaris Sportsman 400, 500, and Xplorer 500 service manual
      This detailed, comprehensive manual covers the Polaris Sportsman 400, 500, and Xplorer 500 4x4 from 1996-2003.
      Submitter davefrombc Submitted 05/05/2026 Category Polaris ATV
