fender plastics ?
By cruteg8
Does anyone know the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way i put it high goes into reverse and vise versa I flipped it 180 but that put the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
By Rockbottom
By Mister907
By en4cer
Problem number 1,
2000 Polaris Xplorer 400. No start, has spark. Has fuel ,found Low Compression less than 60 psi. What to do next?? Going crazy here.
Problem number 2.
1994 polaris Sportsman 400 starter won't engage. Button on left side with light switch seems to be almost stuck in, weak spring behind button?
Any help would be nice.
By davefrombc
1996-2003 Polaris Sportsman 400, 500, and Xplorer 500 service manual
View File Polaris Sportsman 400, 500, and Xplorer 500 service manual
This detailed, comprehensive manual covers the Polaris Sportsman 400, 500, and Xplorer 500 4x4 from 1996-2003.
Submitter davefrombc Submitted 05/05/2026 Category Polaris ATV
