Suzuki Twin Peaks 700, V Twin Water cooled, has 2 Keihin 32mm carbs cant remember the stock jet sizes. It was the same as the Kawasaki Praire 700 only the Suzuki version was yellow. Does it still have the original Keihin Carbs.
Yes same carburetor keihin carburetor
Bigbell, I doubt that changing an exhaust would need more than one jet size difference. It's possible they didn't even change jets. I'd forget trying to figure what size your bike had originally and just tune is as you find it now.
Agreed! It was interesting so many different sizes are available. More than likely it was never rejetted when the pipe was added, i wouldnt pull the carbs just to check that unless you are having problems, although it would be interesting to see whats in it.
You can test the main jet by test riding..  It need a good bit of track where you can hold it at top speed in one of the high gears for a couple of seconds though.
    • By Norseman69
      Hi. I just bought an lt230 1993.  Ive started buying parts for a full rebuild.  But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed.    I was wondering if anyone have one and Could measure how far out the pegs are.  Like the peg the brake is put on and then peg outside of it.  And the one lower down.  So i can recreate them.
    • By Heymax
      I bought a 2003 Bombardier Quest XT 650
    • By blasirl
      Mostly wondering about the 4/110.  I am in need of new tires for my 4x4 and want to also know if I should stick to the same brand/profile etc. for the fronts and the rears since they are different.
