  • 3 months later...
  • 5 months later...
My Kaw 1000 is Shaft drive.  94 K + miles and never had shaft drive issues.  Changed oil regularly or checked never leaked.   My friend had a restored KZ900...carbruated .... with 4 into one header...It was  LYA on the ground fast!   Chains were always a maintenance issue.   But wow chains are efficient way to transfer KA Power!   I had a Yamaha SR 500 'Thumper' ..20K miles and never changed the chain.
Shaft Drives are more maintenance free ,I've had 2 Honda Goldwings & my Arctic Cat 300 4x4 has the Shaft drive as well as Independent rear suspension which I really like !  I've had several Bikes, Both Dirt & Street with chain drive never had any problems providing they were Always maintained!
from strictly a reliability stand point a good shaft drive is far less maintenance and reliable.  You do not however get the ability to change ratios by adding or subtracting teeth on your sprocket.
Yes my Kaw 1000 is shaft drive.  >94 K miles ( I did not put all those on..LOL) It had a trailer hitch when I got it with 65 K miles from a widiow.  But one looses some efficiency frrom the worm gear.  Not that I need it.
The gas tank was rusted when I got him.  I epoxy coated the inside of his tank.   You know when I was in Croatia on a Nato highway cnstruction job the trucks were from the US...CAT with tandem front steering axles.   But from the factory they had "Coated epoxy tanks!
Chains break...My fried always carried an extra makeup link master link with his Kaw 1000.  I was always afraid it would break and lock up the rear wheel.
I’ve only owned one Atv and it was a shaft drive however I think shaft drive would be more reliable since it is sealed and no way for dirt or sand to get in there, where a chain can get damaged. However shaft drive is a bit more complicated so if something does go wrong there’s probably not a way to fix it, so in my opinion chain is simpler and easier to fix whereas shaft is more protected and tougher and more difficult to damage
Yes chains wear and need replaced However, when changed the Chain on my Yamaha thumper ..SR 500...I changed the sprockets also.  That was a fun bike. I would lay out over the tank and stretch out  on the seat when cruising it was like a massage .
A friend had the Triumph 500 Single w/ Chain Drive, it came out in the Mid to Late 70s To compete with the BSA 500 at the time - Very Low geared ,literally Pull Stumps with it ! Fun bike but wasn't built for speed !
Edited by WeeBee
My SR 500 Yamaha was old but low milage when I got him.  Compression release start valve as He was kick start only.  Good hanling.   Did not go thru chains as he was not a "lam Bam Thanky Mamm"  he was made for long performance.   That was a popular bike in Europe,    I still have him disassembled ...in a box.
    • By Yamahahahaha
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
      It seems every ATV i look at to buy used has no title, does everyone loose there title, or do they change hands so often the title is lost in the shuffle. The ones that do have titles are triple the price. I am new to buying used quads is this pretty standard procedure.
      I know all quads are good and tough but thought it might be good to hear opinions as to what member think is the best, from your experiences.
    • By DexKing
      When you and a group of friends decide you want to take a long group trip of camping/riding/overlanding, how far are you willing to drive for your trip? Right now, i find it really difficult to want to drive more than 2-3 hours one way.
    • By roggers
      Hi everyone,
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
