WE had another inch of snow last night.  I have the SXS on that solar Bat charger I bought from Harbor Freight..  I mounted the solar panel inside the window on my shed.  It appears to work great with the sun that shines through the window.  I keep Foreman in the cottage basement where I can watch over him and keep him charged up.
Always "Dress" for the occasion! It's -2 here this morning! My Arctic Cat stays in the garage on the battery Tender when not being used with HEET in the gas Tank!
Edited by WeeBee
Stay Warm & Safe! It's been below Freezing here for several Days now ! High of 9 today supposed to be -20 with the Windchill !! BRRR!
Edited by WeeBee
It was almost 32 F last night.   I always wanted to make a snow angel in my Bikini like I see the girls at the ski lodges do.  But could not lay directly in the snow.  It is cold. It was a bucket list thing!...LOL
  • Haha 1
That should work better, I bought a used Polaris 4ft. Blade & adapted the mounts to fit the frame of the Arctic Cat by welding on some brackets ! It probably weighs close to 70 Lbs.+/-. Works Great ! I think I paid $75 for it! Hope this Helps!
Have you ever thought of using an electric "linear actuator" to lift the pow instead of the wench.  Linear actuators use a screw mechanism to move the load.  They are limited to a short stroke ...10 inches or so.  However they have a lot of lift force and down force.   Security gates use 12 vdc linear actuators.
An actuator  is a rigid set up. . You want some  give  on the plow blade when  it  hits something solid embedded or  a curb.. Without that give  you could seriously damage your machine or yourself.  That's why  blades on plow trucks and  graders are allowed to  " float".
22 hours ago, davefrombc said:
Looks like that connection was  rather "tired"  to  start with
12 years old, it was due
21 hours ago, jen said:
Bummer!  How heavy is that plow?
does your plow have a rubber wear strip?
No it has a metal bottom edge that can be replaced
I know what you are talking about but it wouldn't be practical. Most winters the plow doesn't get used much. This year looks to be an exception. The winch is older so the cable wasn't 100% to begin with.
For now I am going to spool out a foot or two and cut it, then re-attach with cable clamps. In the spring I am going to service the winch fully and will take the cable off. If it looks crappy overall, I will just replace it.
My plow has two large springs so if it hits something solid, it will fold down and skip over the bump.
My Polaris plow blade has the Large Springs as well!
1 hour ago, jen said:
So do you use the winch (got it right this time) that came with the Arctic cat or a separate winch?
My Arctic Cat came with a Warn Winch which was Seized/Rusted up so I replaced it with a Badlands 2500
My heavy gravely blade worked good in wet snow.  My body weight lifts it up..LOL  everything frozen now 5 F last night...last Saturday it was  34F perfect sno angel snow!
Came with the quad so it has been used for things other then plowing
Those springs work, many times I could have been thrown if it wasn't for them
I have always had good luck with WARN winches. I do take them apart and service them every few years.
    • By jay41198
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By flyinbrian365
      What's Covered:
