here my daschund and my brothers
black on is mine her name is fable but we call her FE-FE most of the time
and the white pieballed one is my brothers her name is kiwi
we also have a lab and german sheperd mix, and a maltesse. but i dont have pics of the,
  • 3 months later...
This will be the newest addition to the family.Jan 15th that is.
We currently have on golden retreiver, two guinea pigs, three hamsters and four hermit crabs(yes my 11 year old has crabs!!!!:no:LOL)
Edited by BuckBilly
    • By Callaway
    • By HHurks
      Hi to all
    • By Maddman200
      Who agrees with me that Yamaha atv quailty was one of the best well built quailty machines money could buy, then 2007 came rolling in and they have gone to complete sh**. Cutting corners everywhere they can and made such unreliable machines
    • By hunky
      Thanks for looking!
    • By Need-help-with-quads
