I changed my oil in my 06 yfz450 like 2 months ago and it was full, i happened to check it again a few days ago and its almost empty what is goin on there, can someone tell what the problem is. Theres no way im burning oil like that , the bike doesnt smoke.
Hmmmmm,,,,,,Mystery Oil.......
Did it leak out of the Plug???
How does your Spark Plug look????
How much ride time did you have on it when you Checked it......:confused:
mystery oil is right, im confused:confused:
    • By ButchM
    • By dkgg5755
    • By middlebrookgt
    • By stealthbu
      cost to overhaul trans in polaris 330
