Similar Topics
By Cage
New guy here. Thanks for the add. I know this is a longshot but I’m looking to see if someone has a used or possibly even new Warn/Wide Open 424 select shaft for a 98 Honda 300 Fourtrax. Or, maybe point me in a direction to locate one. Thank you in advance.
By kenikas
I've got a problem with the shift lever returning to the centered position, and it seems the same either upshifting or downshifting. It goes in to all the gears ok, but does seem a bit difficult to get in to gear sometimes, but every shift you have to tap the shifter with your toe either up or down to center it before you can shift in to the next gear. The people we bought it from had only used it to plow their driveway in the winter for several years, and had only used 1st and reverse for a long time. I've tried lubeing the cable ends and the shift lever pivot, but doesn't seem to help. Any ideas?
By Mel4321
Hello People-
I'm working on a 2015 Tactic 800. I need to get at the mid shaft diff to replace the key on the output shaft, under the Y output crown gear. Has anybody been in there? I was hoping to remove the housing without pulling the tranny. I've pulled the tranny before and it was a bear to get out & in. That part of the tranny with just a 1/4" x 1" key stock seems a little week to me, is there anything I can do to beef it up?
Any help would be appreciated!!
Similar Tagged Content
- 6 replies
- 2,264 views
- 0 replies
- 1,805 views
- 1 reply
- 2,238 views
- 3 replies
- 5,299 views
- 11 replies
- 4,851 views
Gallery Images
4
1
0
0
4
5By mannyortiz7,
0
3By blahhhh,
5
2By CK1999_400ex,
0By George Henry,
0By dirtmerchant42,
4
2
4
1
4By mannyortiz7,
7By nyatvrida91,
3By mannyortiz7,
0By SeanKing,
