So i racing sat. Aug.30th at a local track and on the third lap i hit the finish line jump and when i landed my foot must of hit the shifter and i bent the shaft, took a chunk out of my case. so after the race day was over i was talking to some of the other racers and they said the only was i would be able to race this bike the rest of the season without getting another LH case would be to use QUICK STEEL so i went to an auto parts store and picked up a tube of it, its like devcon so i mixed it up and put it over the hole and waited for about 4 hrs. and then came back to check on it and it was as hard as steel so i started the bike no oil was coming out of the motor but i could still feel air breathing out of the motor from the top part of the shaftso i put some more on there and hopefully it works untill the race season is over.
ill keep everyone updated on what happens
If it were me,,,,I would order the Case,,,,Have it handy.....Ive never delt with that stuff and Dont know anyone that has......Just seems like it is still the Weak Link.....
Snap a pic of the Repair:yes:
you like pics mwke dont ya:wink:
Keep a close eye on your oil level!!!!!!!! i just got through replacing my cases this spring on mine due to my chain coming off and busting around the clutch shaft:no: I got a set of used cases off ebay for around $150.. you can get a new set for around $300. just keep an eye on your oil, keep a light left foot, and just remember, if you ride on hills, the faster it will dump!! good luck with it! keep us posted!!
    • By joezee13
    • By middlebrookgt
    • By Ejwill
    • By Need-help-with-quads
