It is tight on the side i have done it several ways, you can usually get a couple of fingers on the top and pull up but easy to loose your grip and it will fall back down it is very heavy. You can pry up one side with a screwdriver and get a grip on it and pull it up, but dont pry against the plastic may crack use a board under it.. If you are replacing it get pliers on each terminal and pull up, but i dont pull on the terminals with the new battery dont want to change them breaking loose.
I've made a 2" polyethylene strap that goes around the battery and gets you a good handle. Polyethylene is more acid and corrosion resistant than most other strapping materiel. I'll post picture when I get a chance. Would have used a large zip tie, but all the larger zip ties I found were nylon which is not acid resistant, a large zip tie  would would do the same
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
    • By sunn
      Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
