We've added some functionality to our internal message system to help when sending PMs.
You can now:
Send to multiple friends at once
Send to ALL your friends at once
Pick from a list of your friends
Send to all Group Members (Groups that you are part of)
To send PMs, CLICK HERE
Curently testing, so please report any bugs in this thread. Thanks!
      I have a 2015 Outlander L 500 max.
      any way to change the start up message in the cluster WITHOUT taking it to the dealer and paying $100???
    • By Eisenmatt17803
      Good Morning!
      Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
      Thanks in advance.
    • By Banshee898
      2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
      Thanks for any help.
      If you live in New York, Come and join my group here on quadcrazy! Go to http://www.quadcrazy.com/groups/?id=1
