Yes you can just hook your jump starter box to the battery and crank it up. You can use a trickle charger on it ,leave it over night, if the battery is good will charge  up. I have so much trouble withr these small batterys not lasting very long i have just been leaving the trickle charger on it when not in use. I usually use aa trickle charger that puts our 1.5 or 2 amp.
    • By tds7
    • By BillR94
      Thank you for your time
      Bill
    • By kx9m
      Retired carpenter here looking for things to do... What else??  Work on old quads sounds good!!
      Here for manuals and advice..
    • By sunn
      Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
