Similar Topics
By Myrtsbnye
Hello All,
I have a 1996 Arctic Cat Bearcat 454 and am in a bit of a quandry. I had a bunch of work done on it over the past couple years...new carb, rear brakes, rear axle and bearings. When the rear axle was replaced the shop noticed the left rear hub was stripped. Problem is, the part (1502-178) is no longer available. I've checked junkyards, ebay and other online parts sites across North America and nothing available. Hate to park the bike after all this work just because of a simple hub.
I have two questions...the front hub (part number 1502-177) how much different would it be from the rear hub? This part is readily available. Would the axles be different diameters?
If these are two different parts and we can't make them work, is it possible to take the existing stripped hub and just weld it to the axle? I know it may sound drastic but was wondering if it would not be too crazy?
Thanks for your time
By Hooks300Bayou
95 bayou 300 2wheel. This is my first four wheeler. The guy I bought it from showed me slight drip on his floor from a drain plug he recently retapped. I figured I could handle a small leak from a second hand machine. Well after a few times of riding it the bayou seems to be running low on oil. Now maybe this is normal operations as well so I refilled the oil. But the next day I notice my drip on the floor was slightly larger. I wanted to see this drain plug for myself so I took off the skid plate and found a pretty rough looking installed drain plug. It does have a small drop but also seemed to have an excessive gasket and maybe some grey looking “jb-weld” ish material around it. So that’s scary but I figure surely that’s not the only source since my floor spot Grew a bit. I went on to find recent moist around the head gasket for the top end. I’ve never seen it drip but it drips on the new starter the guy installed so it seems the head gasket leaks too. He did say he replaced that gasket when I inquired about the darken stains around that area of the motor. He said he replaced that gasket during. Ring replacement when the bayou was smoking. It no longer smokes by the way. So I continue on thinking well maybe I can do another top end gasket myself some day but still the oil on the floor suggests a more visible leak. I mean it’s not a lot but it grew as I mentioned. Then I find my what seems to be an awful thing. The pull cord and starter was replaced by the preavious owner and it appears there’s a busted area on the crankcase where the left side cover mounts to the L-case.I have not seen oil from there but that looks scary to me. Does this area hold oil? I wondered if it doenst maybe I’ll leave it be but if it does it’s probably the reason I lost some oil. I also found tonight oil on the rubber boot cover I think is for the drive shaft or something. Idk my first ride so I’m unsure of how to proceed. Especially with the case cracked like that. I don’t know how the engine works but if there is indeed oil there in the operation of things it seems like I must do a major engine over haul….. any insight would be so very helpful. I bought this for my daughter but I may have been bitten by going with such An older model.
By geezer99
Howdy from Oregon!
I'm wanting a SxS for operating on my own property. I would use it to haul chainsaw, cables, axe, machete and other stuff to maintain several miles of foot paths. Also I would use it to make the daily 1 mile round trip to the mail box. I expect I would use it a hundred hours per year.
I am grossed out by the price of new machines, and after reading the service manual of a Polaris RZR 400, I am not happy with the maintenance required either. It seems a used machine has quite a number of areas that would be potential problems if a used machine wasn't kept up properly with maintenance.
4x4 quads seem a lot cheaper, and simpler to maintain, but have the drawbacks of no "bed" and maybe? side-hill stability.
Your thoughts, please?
tom
By carlneedwindshield
Hey Guys, we are looking for some good windshields and back windows for some customers and we came across Flex a fab as a manufacturer, does anyone know about their products?
Hey guys, we are looking for a manufacturer to build our windshield and back window, we found Flex a Fab, does anyone know about their products?
Similar Tagged Content
- 10 replies
- 4,094 views
- 7 replies
- 5,074 views
- 19 replies
- 8,430 views
- 2 replies
- 1,961 views
- 9 replies
- 8,354 views
Gallery Images
