i was out riding and i heard a sound that was like a snap and my bike shut off and wouldn't start back up and the only thing that i can visually find wrong is there is a crack in the exhaust. would the crack in the exhaust keep it from starting??
1st Check spark, Then check Fuel, Then check compression. The spark should easy to see if you take out the plug, lay it on the head, & push the engine over by hand. The fyel can uasuly be determined by looking at the plug, is it dry ?? The motor shoult have some resistance to being kicked over, No resistance=no compresion. Hope this helps, you can get back to me if you need more help, I am a technition,
  • 7 months later...
dude it is most likely that ur engine needs to be rebuilt. u sould have taken better care of it because i have had a stock 1996 blaster for 3 years and have not had to rebuild the engine once
Hmmmmm,,,,What part of the motor do you think he should rebuild???? Please be as detailed as any Arm Chair mechanic can be....Im sure after a Yr. he might need some help with this:laugh:
I believe in regular maintenance,,,,However,,,,That doesnt always prevent a Catastrophic failure....dont be so fast to jump the gun kiddo
o sh*t i think i know what the problem is i fixed my old blaster and sold it but i dont know what its called its somthing in the clutch area its like a silver lookin button thing and when its pushed in the blaster will run perfect when its out it starts burblin at top end and stalls so i just cut a screw and jamed it in their keepin the button pushed in and now it runs fine.......sry im a bad help
    • By quadnut20
    • By Mister907
    • By Jdeaton011989
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
