Similar Topics
By highlifter22
Good evening, looking to up grade my clutch springs. There are so many different colours and combinations. Looking for the best colour combo. Any help is greatly appreciated 😊
By Hoyt1500
Has anyone used the Boyesen Power Reeds on their LT80? Did they provide more power? Are they worth the money?
By rgeiser
So a costumer braught in a 2018 general and the damned clutch wont come off....... I had one of the old style polaris pullers so i packed the shaft with grease and ran the bolt in. bolt got tight smacked it with my purse. didn't budge. so I had the correct puller ordered and got it in today "Super atv" greased the bolt shoved it in tightened by hand and what do you know puller bent when hit with impact now its useless so yep thats where im at. gonna order another puller but i dont see a factory tool. thaughts?
IS it ok to heat the primary on a polaris?
By Acme54321
I am trying to run down a problem with my Bayou 220. I think it's a 96.
The battery has been dead for years. Years and years. It pull starts right away and I don't use it a ton so I hadn't bothered to put a new battery in until now.
I've got a new battery in it and now nothing works that should (and used to). The starter, headlights, and dash lights are all inop. I've looked at the wiring diagram and done a little messing around and haven't had any luck.
Fwiw the starter works when jumping the relay. The 4 wheelers pull starts and runs fine.
Any ideas where to start?
By mga
on my 2k big bear 400, there's a clutch adjustment on the side that says "increase" or "decrease". Only thing service manual says to turn it one way or the other.
my question is, what happens when i decrease it? what happens if i increase it? does it effect shifting?
I'm not sure if it's ever been adjusted, but, it was tempting to play with...ut, i didn't touch it until i asked you guys.
Similar Tagged Content
Gallery Images
