Fun in the sand
These are a couple of pics my friend got of me shooting some roost in Syracuse, Ks. My quad was running like a raped ape this weekend. I LOVE IT!!:aargh::aargh::aargh: I was too lazy to undo 8 bolts and tighten them back up so I didn't run paddles.
This is me coming off the top of a hill, smiling for the camera, of course!
This me having a little fun on the face of the hill.
This is me doing my best to bury the cameraman. Without paddles I just couldn't get what I needed to do so. Not bad for a machine without paddles, what do you think?:wink:
    • By Spritee1
      not sure where to look next
    • By NZrider
    • By jatho
    • By mkibbe
    • By jatho
