I have a 1998 450S Foreman and my brother has a 2002 450S Foreman. We both bought them new. Ever since I purchased the machine it was very hard to keep it straight on pavement over 20 mph. My brother says the same thing about his. I just noticed after 8 years that the tire wear on the left front is worse than the right front. Measuring the distances from the rear of the rims and the front is over 1.25". One wheel was toed out dramtically....my brother's too. I adjusted mine so the dimensions are the same from front to rear on the rims and it drives perfect now. We are wondering why this is on the same model 4 years apart. Strange. I'm sure there is a toe-in toe-out dimension but our ATV's toe-out on wheel is dramatic. Does anyone out here know about this or has the same pr:confused:oblem? Very curious, in Curtice, Ohio. :skeptic::skeptic::skeptic::skeptic:
Yeah BuckBilly is right: checking the alignment is not part of the dealer assembly or PDI pre delivery inspection. i am unsure about their logic for this but am sure it has to do with the 4 wheel drive. and they WON'T pay for it under warranty.
Your tires and the traction surface will make it more noticeable of course.
When I changed tires on my 660r, it about threw me off on pavement....turns out it was toed-IN over an inch!!! It didn't know which way to go!
You can change the toe on your Hondas with a tape measure and some patience, it's easy.
Sorry, refresh my memory: isn't the Foreman the one with full-time 4WD or is that the Rubicon? One required aftermarket parts to make it 2WD, I dont remember which is which. At any rate, I think they toe-out to enhance straight line stability at low speeds- they're not highway rigs of course. It's good you found it. go to 'zero' or toe in like 1/4 inch and see how you like it! Honda did that for a reason but I'm not sure it was a GOOD reason.
i know this wont help but the foreman needs the 424 select cause it is all time 4x4 to change it to a 4x2... the rubican all depends on wat year for it to have all time 4x4 or u cant switch it if im correct about that
I think youre right there, thanks for the refresher! fulltime 4WD is often toed out so it doesn't 'crab' so hard in a tight turn. Your 4x4 PU does it too when the front end is locked. it's actually meant to make the tires last? but that's the theory...
01 and up Foremans are part time 4x4. Honda does toe in on most 2wd and toe out on 4x4s. Ralph ( Honda Mechanic) Told me the manufacturers claim it make them handle better. My Ozark will go great and straight on dirt, but pavement while give you the squirts.
On my sport, they are toed out about a 1/4 inch. I have no problem holding a line in dirt. On pavement the thing handles like it is on rails. I think that has a lot to do with my tires. I have hit 5th gear on the pavement and it doesn't drift at all.
I always mix up the Foreskin and Rubycorn as they were SO similar for several years, but the Rubicon was the Cadillac of that class.
toe out a 4x4, toe-in a sport quad like you would a 2wd car. mine is toed-in 1/4" and it took a whole afternoon to get it all right, but it's worth it! my tires still look like new and steering is smoooooth..... Bot1 will testify to that! I am sorry DrtyGrl didnt get a chance to ride my Raptor- it's kind of an experiment on wheels....
If anyone needs more instruction on how to check alignment, I'll be happy to help you. just let me know! ;p
  • 10 months later...
After reading this thread, I wonder....so 4x2 is usually toed in and 4x4 toed out? Is this correct, and 01 foreman hondas and up can be both. Mine is 2 and 4 whel drive selectable (07 trx500fe foreman). It is toed out a bit and the service manual says it should be toed out about 1/4" I believe. She seems to handle just fine off road and a bit wobbly on road ay higher speeds in fifth gear, but she is an off road bike so not real worried about on road handling or should I be...?
  • 7 months later...
    • By Atomusthenes
    • By Tim Keiper
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
