So listen i picked up a 2000 yamaha warrior last year i think.. heh
eithe way it needed a starter...
so i put one on.. along w/ new battery cables, refilled & charged the battery, did the clutch, main/rear sproket, new.ish front tires --- rode it from jan-sept ::: & then it sept after taking on a full day of riding one saturday w/a buddy of mine & his scrambler.. the next day some1 came to buy it & it wouldnt start... so i repleaced the ignition coil on it.. as i put a volt meter on it.. & it had no spark...
Still wont start... i think its the CDI box, but how do i know for sure???
it went from running like a champ... to no spark @ all.. & so yeah its been sitting for a couple months... & i want to get it ready to ride in the snow again.. so what do u guys this is wrong???
should i dump $125 on a CDI box, or could it be a Stator, or just a voltage regulator... the battery is putting out more then enough juice... to power the lights... & u can hear the starter tryin to crank the engine over...
HELP!!!!
oh yeha & for some reason the neutral light doesn't work -- the bulb appears to be fine...
make sure your kill switch works, then turn power on and test to see power is going into the CDI. If it is, then it's prob the box, if it isn't then you may have a switch not grounding or a poor connection on the battery. the CDI needs full power to work/test right. Very hard to diagnose without having it here to check over, sorry.
hrmm
okay so i guess ill pic up a CDI box.. for cheap...
& see what happens.. maybe i just flip the quad for something else...
Sorry, but there is no way to positively tell you what's wrong without having it here to test. I don't want to tell you it's something expensive and then it's not. I gave you a couple test ideas there, see what happens!
the weird thing here is that CDIs usually crap out when they are HOT, not sitting in a garage. Did it quit while you were riding it last time? and then start after it cooled down? did you try a different spark plug? yes they fail routinely.
Please do the obvious stuff before you go spending a bunch of money OK?
Edited by Raptor8
well i replaced the CDI box.. & got a new battery...
& it still wont start... so i guess it must be the Stator...
I can get a new stator for $125ish from parts unlimited...
oh well... now im in no rush to fix it again.... heh
any1 want to trade...
or maybe ill part the quad out.. heh
Did u check the relay and neutral switches???? I have a stator for a 97 warrior i think it will fit your quad, its brand new, i bought it with the cdi box from rm stator because when we tore down my quad it wouldnt start when we put it back together, it turned out to be corroded wiring, relay and neutral switches and the cdi. Didnt need to replace the stator.
Check the spark plug boot, it should actually screw on the the wire, and sometimes the wire wears away and loses contact with the screw in the wire end of the boot. Take the boot off, then strip away a little of the insulation on the coil wire until you see fresh wire, then screw the boot back on. This is one of the cheapest and easiest scenarios.
Did you get this going? What's the status on this machine?
    • By cfherrman
    • By logray
      Hi all,
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
