Join Today, It's Simple and FREE!
By Rich Arno
Hello. I'm new so I hope I'm posting in the right place. My neighbor gave me a nice looking Bayou 220, but I can't get any fire to the plug. No lights, nothing. So far I've put in a brand new battery and relay. So those are good for sure. No neutral light comes on when the key is turned. Where should I start to try to figure out this electrical problem? I have a new coil to install, but common sense tells me it has to be something before that. I'm cheap so taking it to the dealer is out of the question. Does anyone know the process of elimination in a situation like this? I'd might add it LOOKS like the wires are all where they belong, but I can't say they are for sure. If the machine wasn't in such great shape, I wouldn't bother, but the grandkids should have a lot of fun on this. Thank you in advance for any help someone can offer.
By e.p.
Hi all;
New to the site. I have a 2004 Yamaha Kodiak 450 YFM45FAR that I'm having issues with the gear indicator lights. I'm having intermittent park and neutral lights and when they are not lit the starter will not work. It will start by the pull cord . Anybody else have this issue. Any help is greatly appreciated.
Thanks.
By Ajmboy
I am starting this thread as it's that time of the year....I'm planning to put some up myself, nothing crazy, maybe my 2 front trees and hand rail. When I do, I will post a pic in this thread.
Has anyone else put their house lights up yet? Post a pic!
By donens
Having light problems on 1983 Yamaha YTM200E. The lights all work when using the ignition key switch, while not running. However, when running and using the handlebar switch the lights will not work. Using the repair manual from Clymer, attached, I checked the lighting coil and voltage regulator. The lighting coil ohm test is within spec. However I cannot any continuity from the regulator between red and white wire in either direction.
Got a used voltage regulator, but it failed the continuity test as well.
Can anyone help?
Clymer_RepairManual_Regulator_Rectifier_Test.pdf
By innosol80
The brake light son my ATV are not working. I replaced the brake light switch and still nothing. Any ideas? Thanks.
