By Ajmboy
By joshualutz
By USRaider
Hello all!
By tin
By JBuckeyeJ
I got the old thumper going. My best guess is it sat in a barn for the past 10 years. Now that I know it runs, it’s time for a valve adjustment and tracking down a clutch cover.
