A quick question.
My sons 2001 sportsman 90 does not like to start after it has been sitting for about 2 weeks.
I have to crank it a large number of times before it will start up.
Any suggestions on what I can do so it will start up easier?
Everything seems connected correctly and nothing seems loose, I have not pulled the plug as of yet. It is on the to do list.. It runs great once it does start and then I can stop and start it repeatedly with no issue. It's just a bit frustrating with my son waiting to ride and the #$^%@ thing won't start.. :aargh:
Thanks in advance.
- John
The two times I have had issues once it was warm and once it was cold, but I was inside in the garage and the machine was warm when I tried to start it. I will pull the plug when I can find a few free minutes at home.
PULL THE PLUG!!!!!! LOL!!!!
Yea,,,,Check the plug.....Ill bet it is Fouled.....Also,,,,I hope you are Draining your Carb Bowl if you let it sit that long.....If you are keeping mixed Fuel in your Tank.....And letting it sit that long between Starts.....You might want to Give the Bike a Shake or Two before opening the Fuel Petcock.....:yes:
Well pulled the plug yesterday, it was relatively clean and gapped correctly. The only thing I noticed was that is was not that tightly screwed in. I brushed it clean and put it back in and of course it started right up. We will see how it does... I suppose I just need to get it out and have my son exercise it more :)
    • By realpilot
    • By OldATVowner
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By LMI
    • By flyinbrian365
      What's Covered:
