Opinions NEEDED
Spooge
u could go with ur first thought about getting a polaris they are good strong machines but with the old models actually all old model bikes u have to get a lot more info from the seller to make sure ur not buying junk... is their any manufacturer u prefer more over others or info u want to know about curtain manufacturers?
Right now it seems that a polaris sportsman 500 4x4 is my best bet (or something like that) Hows the quality/reliability on those?
I havent contacted the seller... by the time Im ready to buy this one may be long gone. I was just asking about reliability in general. I know the obvious things that could be wrong with buying used and I know how to/have experience with buying used... I was asking more generally if they have any problems that are very common/known to happen.. things that the brand is prone to
    • By Spritee1
      not sure where to look next
    • By justent_88
    • By mkibbe
