The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the quad. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
You would be fine running the higest octane from the pump.
Nicely said..:yes:
All true, octane is resistivity to combustion. Meaning higher octane fuels don't pre-ignite under higher compression. While you don't need to run race fuel you will find advantages. The biggest one being that your motor will run cooler. High octane fuels burn slower and cooler than lower octane fuels. As opposed to lower octane fuels which burn quicker and hotter. However, for optimal performance, I have heard the lowest octane fuel that does not pre-detonate is best.
Edited by DirtDemon
What everyone said is correct.....I would be more concerned with What Pre-mix you were runnin...Meaning what Ratio....the Leaner the meaner is the way I go....
I think if you have Stock Comp. 91 Octain is fine....The key from here is your Mix.....I think the Factory Sticker on your Trike is 20:1.......On my Trike it is 20:1 but have been known to go 50:1 at times:yes: Regularly I run 40:1....However lots of people run 32:1,,,,I recomend Castor 927
Whats all your specs on your motor?? If your compression isnt way up there you should be ok with 91 octane... im around 150 psi on my banshee cylinders and im running 91... 32:1 with Klotz Super Techniplate oil...
Guest roach
i have heard that pump gas is never the same year round like race fuel so it makes it harder to keep tuned correctly.any comments
have a buddy th@ says that fuel isnt the same as back in the day when the trikes where the thing..:elvis:
In the 70's lead content in gasoline was worth talking about. In the early 80's most leaded gasoline was the exact same as the unleaded. Unless you went to a farmers Co-op. The it had lead in it for Tractors. Most insurance companies charged gas stations more if they really sold leaded gas. That is why most gas stations in the 80's sold leaded gas that was really unleaded.
    • By PupATV
      Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
      -PupATV
    • By bhristianzx12
      I have acquired a free 92 Polaris 350L 4X4. Ive replaced carburetor from ebay, replaced spark plug, im trying to pull start but sounds like it doesnt want to fire. Spark is a bright orange spark (checked with spark plug tester), replaced plug, pre mixed gas from an external gravity feed tank. Compression test good. Anyone got any recommendations for me?
    • By maikytech
      Has 60 psi and motor recent flooded...what the true compretion
    • By jhamrick75
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
