By quadcrazy
Why Riders Like It
2. ITP Cryptid
Features
3. Outlaw 2 ATV Tires
Pros
4. STI Out & Back Max
Highlights
5. SuperATV Assassinator
Features
25-27 Inch Tires
Bias vs Radial Mud Tires
Bias Ply Tires
ATV Mud Tire Maintenance Tips
Final Thoughts
By tflack500tbx
Background,
Any Ideas?
By vlxerdon
Hello from southeast Georgia. Was gifted a 2000 Yamaha bear tracker with out a carb or battery and looking like it had seen better days. Was told it had sat for about three years. Explained a lot. Put a carb on and a battery in and it started right up. Surprised the heck out of me Anyhow as stated in my opening I am 78 years old with a very long motorcycle backgground but brand new to atv's. Anyone else out here from Georgia? Would like to meet up with some folks for a ride or two. Looks like a great site. Thanks for having me.
Don
By mikeexplorer
