By quadcrazy
QUADCRAZY NEEDS YOU!
By mikeexplorer
By davefrombc
It would be helpful at times to have a button where we could cont the Admin. to make some changes to our posts.
By Maddman200
Hello, I am in need of some help with a subscription issue, can an admin please message me that is able to assist me. I am trying to download a manual says I need a subscription but then I check and it says I have a subscription and when I go to try to buy a subscription it won't let me cause it says im subscribed already. Any help is appreciated. I have uploaded a few manuals in the past to help the library grow and have many more I can add as well.
Thank you for your time
By David Cameron
The small waterline insert for the hose that goes from the water pump cover to the thermostat housing has corroded off. I only need the insert on top and behind the thermostat housing that the hose goes over and can't find just the insert. It looks like it may be pressed in. I've have been told the entire motor housing needs to be replaced. The pic with the red line indicates where the hose and insert would be and the insert looks like the pic of the water pump Any ideas would be really appreciated.
