I posted this in the general talk area, i didn't know if i posted the link the video would just play on this page so i thought i would put it in the right place so here ya go. [ame=http://www.youtube.com/watch?v=5g0uyH8vB1Q]YouTube - Oregon Dunes Apocalypse Two[/ame] Comments appreciated, any way we can approve, things you would like to see in our videos to come just let us know. We are also planning a trip to St. Anthony idaho June 22nd through the 28th so we will be filming for another video that will probably be out around July 4th or so if we don't run into any technical difficulties. Hope you like it, Keep on riding!
This was filmed in Christmas Valley in eastern oregon, over in the "hidden dunes." none was actually filmed at the coast.
Thanks for fixing that mistake too, we are new.
Thanks for all of the input, tell your friends to watch it !!!
Wow that video makes me want to go to Christmas Valley now..
Haha
    • By BillR94
      Thank you for your time
      Bill
    • By mikeexplorer
    • By wjmedic
      right front hub again
    • By sunn
      Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs?  Right now that panel is wide open with excess heat on my leg.
    • By TravisCr
      I live in North Eastern Wa, in Collville, and I'm trying to figure out if there are any good regional used parts dealers around here- Our town had a decent Polaris dealer- but dealer prices are what to be expected these days.
      I've got some random little pieces I'm looking for and tired of scrolling ebay (2003 Polaris Sportsman 700)
      These are odds and ends stuff and I'll probably end up on ebay- but figured I'd ask.
