trailblazer wont start....
By TomJulio
My 1992 TRX00 recently stopped firing. I understand this is a common problem. I have ordered an aftermarket CDI unit. TJ
By Guest
By RGS
By Atomusthenes
By ncutts
hey all looking for some guidance on my KQ just replaced stator, and regulator on the quad and after putting all the plastics back together and finishing the snorkel kit she has no spark when i check voltage on the power wire going into ignition coil im getting about 12v and if i crank it im not getting my "peak voltage" (80v) any help would be greatly appreciated
thanks , Nick
