Well this month we didn't do so well at the mud bash again. Sure not bad crowd but still went into the red in this mud run. Because they didnt have the radio station come in. Because everytime they have the radio station out a lot of people shows up. Had Palmer's mud bash shirts again in different colors Orange,Pink, and Dark Green. Also have 2 different kinda of Hat's now this month. (Same camo 1 , and a black 1 with white/red flames) Also got rear stickers for your windows.
Left the house about 6:00-6:30am again because we forgot to fill up the atv before we left, and got to the perryville exit about 7:30-ish to eat at McDonalds there, and had to do another 20-30minutes of backroads to the house. So got there about 8:20am. People already was there, and people started showing up when we pulled in.
But overall pretty quite crowd besides that 1 red chevy with the loud exhaust I swear he was never going to stop driving that truck. Everyone wished that truck blew its motor already with that high pitch noise.
Also meet smurfblue3 on quadcrazy also. Did I mention I also had to push his atv back to his truck lol.
Click the picture to see it bigger
The biggest truck there.
This guy was trying to drive into the mud pit in reverse but you see how far that took him lol.
Finally got the atv alittle more dirty than last time atleast but it was a lot more dusty eariler that made a nice tan coat.
OOPS!
Just some random pictures
yeah yeah I can't help it the ol honda didn't want to run...... next mud run you gotta hop in the short bus with me!!!! don't know if the honda will be smoking next time or not got a new motor just got to get it on...
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
      Are there any good mods for adding a radio, or Bluetooth speaker that's kid friendly? My son thinks he needs music while riding around.
    • By Topendcol
      Col
    • By Whiterabbit
      Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!!  I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
    • By Mikael
      I recently bought and old Kazuma Dingo 150cc and to begin with it started just fine. Then, for no apparent reason, it wouldn't start. It turns the motor but fuel isn't getting to the spark plug.
      As mentioned in the title I've since replaced the fuel filter, the carburetor, the ignition coil and the spark plug. Fuel comes into the carburetor but seems to go no further. Is it a vacuum problem? Does anyone have a good idea about how I could diagnose the problem? And how to fix it?
      I don't know what year it's from, sorry.
      Sincerely
      Mikael
