welcome to QuadCrazy. The problem you have would be that your shift linkage needs to be adjusted if it goes into low and reverse your problem would most like be that it is pretty simple to fix. When you try putting it in high gear does it sound like the gears are grinding a little? Check the oil level two in the transmission case
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
