i know that you can get different bearings that will alow you to put the banshee hubs on the fron of the honda .. i have a friend that has them on his 400ex cause they are lighter than the honda hubs ... he uses his quad for drag racing ... i dont know the sizes of the bearings or if the year of the hubs matter but ive seen it done ...
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By wjmedic
      right front hub again
