Purchased a 1993 300 TRX (2 wheel drive) Problem i am having is the headlights "blink" somewhat at idle but get very "dim" when RPM is increased. Grounding issue possible or something wrong with volt regulator. Any help greatly appreciated!
I think you are on the right track, check your electrical connections, grounds, wires and connectors. If it were a rectifier/regulator, then you would probably have charging issues as well. Use a multimeter and check the voltage at the headlight plug. If it is ok, try replacing the bulb.
  • 10 years later...
    • By Dsluder
    • By Shorty51
    • By Jdeaton011989
    • By gordonmacritchie
      all fuses are fine
    • By cruteg8
