Affordable entry level 250
By BillR94
Thank you for your time
Bill
By wjmedic
right front hub again
By sunn
Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs? Right now that panel is wide open with excess heat on my leg.
By Gwbarm
I have noticed lately that the ATV tires i generally buy have upped in price quite a bit. The Kenda EX that i generally get are sold out and not available at this time, the EVO which is usually my second choice has increased 50.00 on a set of 4. The HTR Kendas best tire is now 150.00 per tire. Even the Sun F have increased but not so much as the others.
By 86ccord
