CEDAR CITY, UT - Nov. 9th, 2009 HCR Racing is proud to announce the release of their latest Arctic Cat Prowler XTZ Long Travel Kit for only $5,799.00 at the 2009 SEMA Show: [ame]
[/ame] .HCR Racing's Long Travel Kits include:Custom Tuned King 2.0 Reservoir Shocks/Black or traditional blue for best color match Summers Brother's Racing 4340 Axles Laser Cut for
More...
    • By tepin
    • By Shorty51
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By spigmef
      I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
    • By ath1981
      Got a 2011 425 EFI. It eat 2 belts, so I replaced the drive clutch assy, rollers, spacer and movable face. Put on a new belt and after 30 min of riding, it eat another belt. any clue what can be causing this?
