1997 Yamaha Warrior exhaust valve
By marlon smith
By LCP92
By DexKing
By Rick Shropshire
By MOORETARHEELS
I have a 2006 LT 80 done a top end rebuild and only have 80psi. Any suggestions on what it could be.
