What year is this machine, and is it not running at all? Does the quad start up and then die? Is the battery good?
* Removed your other thread as it was the same as this one.
Edited by Ajmboy
I changed the title a bit, but we would still like to add the model year like Ajmboy said. If you tell us a bit about what is wrong with the machine, what works and what doesn't, then we might be able to help.
    • By marlon smith
    • By dkgg5755
    • Guest
      By Guest
    • By middlebrookgt
    • By T37Mark
