I figured since I won't be able to ride for a while I will make some visual changes. I'm going to repaint my frame Honda red, my subframe is going to be a bright yellow along with my hubs. I will do my lower A-arms red and the upper arms will be yellow. I will keep all the plastics and wheels the same. My swingarm will be black.
Here is what I got done today...
Day 1
Powder coating is the way to go. If it were me though, I would go with the same color orange that is on the side of your seat and handguards, instead of the yellow. I think that color goes well with everything now, the yellow seems like it would clash a bit IMO. I think sticking with the red is a good idea, I think it looks good, and I think the black swingarm would look good too. I have been thinking about doing mine next year, everything will be going matte black if I do anything.
I'm waiting on a few parts to arrive. A few new bearings, sprockets, and chain. As soon as those arrive I will be able to make a lot more progress. I still have to paint my A-arms, it has been too cold to paint thrm. Stock arms can't be PC'ed...
I notice you went with Lone Star a-arms instead of painting the stockers. Have you figured out what you need to adjust the shock pressure to so it doesn't ride too soft. The wider stance looks good, are did you run a different offset on the rear wheels to widen the rear out, they look like they have a bit more offset than standard. Looks like you stuck a wheel spacer in there too. That yellow subframe is looking kind of lonely though, are you going to change the color on anything else to match it?
I ended up busting a ball joint on my stockers so i went that route. Temporarily I have 1" spacers and a different offset on the back to even out the front and back. I found that 65PSI in the shocks works great for what I do. I plan on adding some Yellow radiator hoses
    • By Atomusthenes
    • By Trent Finnessey
    • By Dumass
    • By Arizona
