Hello everyone
can you help me by this question
I have Grizzly 700 SE 2010
1-I need to Install Air intake K&N from trinity racing or complete Air intake with cover air box from EHS racing
2-A custom headers system with dual exhaust From loony tuned and if their are a better exhaust system with headers
3-A clutch system from trinity racing
and if their are a better clutch kit
4-A front Bumper With Rear Bumper From Moose utility
Moose Utility Division - Product Catalog
or their are a better bumper to avoid the rust or the quality it`s not good
5-The kolpin accessories which it`s a good material quality or it`s cheap
6-I need to change the light bulb to
PIAA® HS1 35W=60W Super Plasma GT-X Upgrade Bulb from Yamaha Accessories & Apparel
and install
Lighting Kit
Yamaha Grizzly 700 Accessories, Yamaha Grizzly 700 PIAA 510 Series 35W=60W Super White Performance Lighting Kit
With
Yamaha Grizzly 700 Accessories, Yamaha Grizzly 700 RAM® Rubber Spotlight
so the electrical wire`s will be enough with dynamo charge or their are upgrade for the wire + the dynamo i`ve already install warn winch
please give you`s suggestion about this product
thank you
First off, I changed the thread title, please include the year, make, model, and engine size in your thread titles. All of the products you listed are quality products IMO. Whether or not there are better products out there is really mostly a matter of opinion. I am unsure if you are asking for advise on how to install these products, or just wondering what peoples opinions are of them. If you need advise about installations, I am sure most of these products will come with instructions, and if you have a mechanical aptitude, it should be easy enough to figure out. And I am also unsure what you are asking or saying about the wiring but my best guess is that you are wondering if the stock electrical and charging system will be sufficient to power the additional accessories. I would check with the manufacturer or dealer to determine the output capabilities of the charging system and compare that with the current needs of your added accessories.
    • By Eisenmatt17803
      Good Morning!
      Thanks in advance.
    • By sandman001
    • By marlon smith
