hi 2001 350 yamaha warrior just got ran real good aweek use tank and 1/2 of gas run shut off and wouldnt start put charger on and it start ran for 10 minutes left it out side in the rain went too start it up start try ride it was misfire so put inside came back would not start charger on and start but still misfire took plug out and it was good and look at fuel filter gas run through it can one some please help afriend said the motor is get hard start motor need rebuit
Sorry, I am having a little trouble understanding exactly what you are saying. You aren't using complete sentences. From what I can tell, it sounds like you may be having an ignition or other electrical problem, possibly a stator issue.
Check your COIL and plug wire and boot . Look real good for cracks or sparks jumping . Spray some water on them, wait a few seconds and get in a dark place and start it or try to You'll probably see sparks jumping from the coil or wire or plug boot .. OR... Also the reverse switch can also go bad and do this sort of thing Ground the rev. switch wire to the chassis and see if it helps. OR ride on sunny days . As far as the non- starting problem ,,, Is the Starter turning over but the engine will not start ? Or is the starter not turning ? If the starter is not turning Check the battery connections at both ends . Hope that helps .. ATVDOA
Edited by racers
more
check and insure that the valve assy is working proper. I have found sticking valves on the yamaha 350. if you pull the head, be sure to take your time and note the position of crank to cam.
need help put a starter starter good wend put gas on start to mis put new plug and check fuel filter and gas through itb what should do next thank you hope some help me
Don't take this the wrong way, but, is English your first language? If not, you should have someone help you translate your questions, because I am having a really hard time understanding what you are saying. We would love to help, we just need to understand exactly what is going wrong.
    • By realpilot
    • By cfherrman
    • By OldATVowner
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
