Well, not your average quad.
Sure, it's not a picture of it running across the desert or climbing some hill somewhere but it's something different...much like the quad itself.
We had quite a few bikes there that were really something to see and the competition was stiff...
I'd show more quad pictures...but there weren't any there other than us. I figure most quad owners are too busy USING their quads rather than showing them.
We even had the show's guest stop by and check out the quad and stayed long enough for us to snap a picture of him on the bike!
This is actor Emilio Rivera from the FX show "Sons of Anarchy". He plays the head of the rival bike gang, the Mayans. He was really cool about us taking his picture and was a really down to earth guy.
When all was said and done...and after a really long day...we wound up taking home a trophy...first place in the Full Custom class! Not bad for our first time out. :)
Oh, and did I mention that there was pleanty to look at that wasn't bike related?
Anyway, there are more pictures of the show on our website if anyone is interested...Hog Wild Motorsports | Harley-Davidson powered Iron Horse Quad ATV Enjoy!
    • By PupATV
      -PupATV
    • By bhristianzx12
    • By Cohen9966
      Looking for something similar for my 2018 Sportsman – this helps.
    • By jhamrick75
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
