this is on my 1998 polaris explorer 400. the winch wont work. i had the switch apart today. very coroded inside. i could make it work while it was all apart, but really had to manipulate the buttons. can i hook up a toggle switch somehow? Has anyone done this or do you need the proper switch. mine is a hand held unit with the grip on it. i was thinking i could use a spring style toggle but dont know alot about the switches. thanx in advance.
    • By noticon75
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
