i have a 08 raptor 700 and im running a rev max cdi. i would like to change back to the stock cdi but the problem is it wont work. i tried my friends cdi also and it wont work but they both work on his quad. his cdi has always been stock. my other friend has a procom cdi and i tried the 2 stock ones on his quad also and they wont work. is it possible the aftermarket cdi has changed somthing to make stock ones not work? everyone i talk to said they have never heard of this happening
I think that is really strange, you may need to replace the entire ignition to get it to work, or at least maybe the pickup coil or ignition coil or something. Why do you want to go back to the stock CDI?
i have a power commander and a quick shifter i want to use and they say dont use it with the aftermarket cdi because it has fuel adjustments on it also. when it was on the dyno he cant get it to tune in right on the low end and he thinks its the cdi causing the problem
just noticed when i plug the stock cdi in it shoots a code 33 which is ignition or possible cdi box problem, but like i said my friends quad runs fine with this cdi. is there any way a aftermarket cdi can mess up somthing somewhere else in the ignition?
With electronics, anything is possible, making these kinds of problems hard to diagnose. The best advise is going to come from someone who has had the same or similar problem and got through it. Is there a hard reset procedure you can do to reset the ECU?
    • By Gtc4d
      Thanks.
      Todd
    • By ButchM
    • By dkgg5755
    • By jordan_ATV
    • By middlebrookgt
