does anyone know where to get the bushing for the left side of crankcase my crank burnt up and i just realized after scraping up the rest of the parts i needed that kawasaki doesnt list the bushing
Good luck, I know that particular part is listed with the clutch on most machines, It is called the primary drive gear collar on machines with a manual clutch. I checked the drive converter parts list for the brute force, there is one large bushing listed there, but looks like it goes in the middle of the converter assembly. Try calling a dealer tech, not a parts counter clerk, but someone who actually works on the machines, they should be able to help.
  • 11 months later...
that bushing is only avaible to dealers for factory warranty replacement , i have heard that a shop in lolouisana thats taking the buching out an kurling it then pressing back in an line boring it, also talked with a man in tenn thats trying to get a aftermarket bushing to work, they are already doing the cranks an rods useing toyta main bearings
    • By HHurks
      Thank you!
    • By toe420
    • By Eisenmatt17803
      Good Morning!
      Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
      Thanks in advance.
    • By buriedpast
