I bought this quad about 2 months ago and it runs great. When I bought it the guy said all it neede was rear brake pads. I put new pads on it only to come to the realization that the rear master cylinder is frozen. I bought a rebuild kit for the cylinder and had the cylinder working until I put brake fluid into it. I put dot 3 brake fluid in it and tried to mount it and it had seized up again. I tokk it apart again and now the piston won't go back into the cylinder. I was told that the dot 3 brake fluid may have swelled the gasket on the piston. Can this really happen? Any help or suggestions would be awesome. Thanks!
The only difference between DOT 3 and 4 is the wet and dry boiling points. Your problem might be that the parking brake needs to be adjusted out, or the bleeder may be plugged. Have you checked the guide bolts for notching, this will cause the brakes to hang up and possibly get misaligned which could possibly tilt the caliper piston, causing it to hang up. There are many possible causes, but I am sure it is not because you used DOT 3 brake fluid.
    • By vaneleus
    • By kevinohio
      My cylinder is full of gas.i thought if carb was messed up.gas came out the overflow.had a cheap china made carburator on it.i ordered a factory used one.couldnt find a new one.also the fuel shut off isn't working right.and going to be needing the battery hold down and seat bracket.where can I get a used one?
    • By Olchap
      Thank you,
      Olchap
    • By Joeguy
      Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
      Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
    • By RussB
      Has anyone found a rebuild kit or an aftermarket replacement for the original which costs 500.00 US dollars?
