unless your lug nuts are loose, wheel bearings [or hub assembly on some] are about the only problem it can be. Lots of mud and water right? That means more maintenance.
Well dont really know the history of it but probably.I bought it used and have since had to rebuilt it.Apparently it has had a hard past life.Thanks for the help.I will check it out when I get home from Iraq
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
