If you can't get it loose with some penetrating lube, I think your only option is to start removing the rear axle and inspecting it from the inside. You can give the axle bearings a quick check by lifting the rear end off the ground and giving the axle a little wiggle, you should be able to detect a little movement if the bearings are toast or it could indicate that the axle nut is backing off.
    • By Asand211
    • By TravisCr
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
    • By Whiterabbit
      Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!!  I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
    • By spuukii
      Hey everyone, recent new-to-me ATV owner/rider.
      I have a 2003 Bombardier 650 4x4 Quest and recently my speedo just decided to stop working. The odometer doesn't tick up either but that makes sense considering it thinks I'm going 0mph all the time. I found some links online that mentioned there was a speed sensor to the right of the oil dip but after taking it apart I didn't see anything that looked like what Google images says a speed sensor would be.
      The speedo itself moves to 0mph from the off position when turning it on, the backlight for the speedo turns on, and I can switch between trip mileage and hours. The machine itself rides fine as far as I can tell with no bad effects from it. I tried to find a service manual online but it linked me to a bunch of shady sites and I wasn't trying to get scammed out of $15 each until I find one that is actually legit.
      Has anyone had a similar issue and knows what the fix would be, or where I should actually be looking for the speed sensor? Or at least point me towards a reputable site for a service manual that might better explain where/what to look for?
