08 Big Bear 400 - Engine cuts out at idle and low RPM. Sounds and feels like you turn off the key and then right back on. Sometimes it will die when idling. It does this sitting still or moving so I do not suspect wiring. Runs great at higher RPM no cut out or missing. The machine starts very easily at all times hot or cold. I have checked or replaced the following; air cleaner element, spark plug, plug wires and ignition wiring, fuel filter, carb bolts and gasket. There are no unusual engine sounds. Bike has about 600 miles. I push snow with it and it is very annoying as many times I operate at a low rpm and that is when this occurs. Any ideas would be greatly appreciated. Thanks
    • By Arizona
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
    • By digrig
      Hey everyone,
    • By BillR94
      Thank you for your time
      Bill
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
