ok so its hard to start but will sit there n idle when u hit the gas response fine but it randomly turns off like u turn key off happens alot when u let off gas n starts to idle again the plug sparks like 5 times n then misses a few time then hits 5 or 6 times then misses few times
What makes you think that it is the spark and not a fuel problem? You may just need to turn your idle up a bit. If the machine has been sitting for a bit, then you might want to consider Hondagirl's advise and check the carb, clean it if needed.
