By Fonne
Hi
What machine would you recommend ? - Really want a solid machine since I am no mechanic but can perform a early service myself.
By prdicon
Polaris it a bit cheaper.
Let's say 3-5 years from now.
By Arizona
By middlebrookgt
By alexwv1863
I've been working on this 4 wheeler for a buddy of mine. I got it running yesterday and went to ride it around the yard on a test drive. Well, it backed out of the garage fine, but when I went to move forward, it wouldn't move at all. While giving it throttle, the bike would lurch forward as if I had the brake on holding it back. Then it died died on me and wouldn't crank. That sounded like the starter was bound up. It's a new starter that I put on not long ago. It's an aftermarket. Also, when I would rev the engine up trying to get it to move, it sounded like it didn't have much, if any, power. It just wasn't revving right. Anybody have any thoughts as to what could be my problem now? The guy doesn't know what was done to the 4 wheeler by a family member. So anything could be wrong with it. Also, it rolls just fine when I had to push it back in the building. I couldn't hear any clanking or rattling in the rear end.
