By Rockbottom
any ideas how to correct
By middlebrookgt
By MOORETARHEELS
I have a 2006 LT 80 done a top end rebuild and only have 80psi. Any suggestions on what it could be.
By xxjeanxx30
so i have bought a quad (1985 suzuki LT250E) and the quad had the wrong spark plug and was not tight enough I now have dirty tread and a compression leak what would be my best option try to force the spark plug or take a tap and clean the tread ?
By DZL1
Question for you guys. I have a 98 bayou 220 that I picked up cheap cause it's wasn't running. So it's has very low compression. It is getting spark and fuel.
What should my next course of action be? Any other tests I should perform or where to start looking?
Thanks in advance.
