I ADDED THE POWER COMMANDER 5 ON MY 2007 RAPTOR 700 ON FRIDAY ....WELL I CONNECTED EVERYTHING RIGHT BUT WHEN I TURN ON THE QUAD IT SHUTS BACK OFF AFTER 5 SECONDS OR SO.....ANY SUGGESTIONS? THANKS :aargh:
My guess is that you did not hook it up correctly, maybe it isn't grounded properly. Either that, or you have a faulty unit. Double check your connections, make sure the ground wire is connected securely to the negative battery terminal and make sure the plug is pushed all the way into the socket on the injector and make sure the stock plug is pushed all the way into the input socket on the PC5. If you can't get it too work, take it off and see if it still runs without it. BTW, next time you have a question about your quad, post it in the branded atv forum, this should have been posted in the Yamaha forum.
    • By Gtc4d
      Thanks.
      Todd
    • By Adamb2025
    • By BillR94
      Thank you for your time
      Bill
    • By jordan_ATV
    • By joezee13
